CLD Question
When i Engage the CLD the light does not come on as the manual says it should. I know the CLD engages as i have used it and it works like a charm, but still no light. IS this just a bad bulb or is it an indicator of something worse coming my way.
Thanks in advance edit: cdl |
CDL center locking differential
How do you know it is engaging? I highly doubt the bulb is burnt out since they use LED's in the DII's instrument cluster. Either it is not engaged all the way or the BCU is not reading that it is engaged. |
Originally Posted by Spike555
(Post 198011)
How do you know it is engaging? I highly doubt the bulb is burnt out since they use LED's in the DII's instrument cluster. Either it is not engaged all the way or the BCU is not reading that it is engaged. As always thanks in advance. |
You can also go right and then forward to engage lo-locked.
Here is what you need to do, in your drive way engage the CDL and then jack up one wheel of the truck and try to spin it, if it does not move then you are locked, if you can spin it a full turn it is not locked. If it is locked but the light is not coming on then it could just be a bad/dirty sensor on the t-case. |
(Post 198046)
Here is what you need to do, in your drive way engage the CDL and then jack up one wheel of the truck and try to spin it, if it does not move then you are locked, if you can spin it a full turn it is not locked. If it is locked but the light is not coming on then it could just be a bad/dirty sensor on the t-case. Looks like i'll have something to do after work maņana. Thanks for the help |
If your CDL is working, then either the t/case switch is stuck or has failed.
Originally Posted by Disco Mike
(Post 198121)
