CLD Question
Old Sep 13, 2010 | 07:03 PM
FightOnUSC79's Avatar
Default CLD Question
When i Engage the CLD the light does not come on as the manual says it should. I know the CLD engages as i have used it and it works like a charm, but still no light. IS this just a bad bulb or is it an indicator of something worse coming my way.
Thanks in advance
edit: cdl
Old Sep 13, 2010 | 07:43 PM
CDL center locking differential
How do you know it is engaging? I highly doubt the bulb is burnt out since they use LED's in the DII's instrument cluster.
Either it is not engaged all the way or the BCU is not reading that it is engaged.
Old Sep 13, 2010 | 08:18 PM
i went out this afternoon and did a few runs on the outskirts of Mesa, but nothing major. I engaged it and crawled up a few small hills, but maybe it wasn't in although the difference in climbing was felt instantly. Other than dropping the trans into N and shifting the shifter into low and left what else would have to be done to engage it.
As always thanks in advance.
Old Sep 13, 2010 | 09:17 PM
You can also go right and then forward to engage lo-locked.
Here is what you need to do, in your drive way engage the CDL and then jack up one wheel of the truck and try to spin it, if it does not move then you are locked, if you can spin it a full turn it is not locked.
If it is locked but the light is not coming on then it could just be a bad/dirty sensor on the t-case.
Old Sep 13, 2010 | 09:44 PM
Looks like i'll have something to do after work mañana.
Thanks for the help
Old Sep 14, 2010 | 10:00 AM
If your CDL is working, then either the t/case switch is stuck or has failed.
Old Sep 14, 2010 | 11:27 AM
Is something i can handle over the weekend? if so, will the rave manual explain?
Thanks for the help
IBUFFEM
Mar 25, 2013 07:22 AM
Randall in NC
Mar 24, 2013 04:27 PM
bullcrew
Jan 11, 2012 12:10 PM
FightOnUSC79
Jul 21, 2010 11:02 PM
ajh
Sep 17, 2006 02:36 AM
