Cleaning rocker Shafts
i've used oven cleaner on a number of engines and components, at least as a first step. set them in a disposable baking try and spray them -- in a well-ventilated area of course. you don't have to worry too much on steel parts (like rocker shafts) but aluminium can be damaged if you leave the cleaner on too long.
I bought him with 250k and have only driven him 2200 this first year I've owned him. I just changed the oil, which was still amber. I am cleaning the valve covers with oven cleaner, and yes, you can"t leave it on very long before rinsing it off.I did the PCV upgrade. Before I remove the rockers, I am putting each cyl at TDC and hooking up an air supply to check for air escaping via the rings & valves. I also bought a fuel injector tester/cleaner. More pics and details to follow.
YouTube is my friend, you put the posts in a vise and gently twist the shaft by inserting a suitable rid in an oil hole or post hole and DON'T use too much force. I cleaned the shaft with HD Easy Off first to remove as much varnish as possible. Going to use a brazing rod to clean out the eensy beensy oil passage holes (what a joke).
