Clunk in the trunk
Old 01-10-2011 | 06:39 AM
Jason Smith's Avatar
Default Clunk in the trunk
Just purchased a 99 LR Disco II with 126,000 mi. on ebay, it was delivered Thursday of last week. Typical of buying online it was a mess, dirty from one end to the other but that is the easy part. Once I started driving it around I have noticed a clunk in the transmission or rear diff. Doesn't appear to be driveshaft related ie: uv joints. What do you think?
Old 01-10-2011 | 07:55 AM
When does it clunk, how do you know it is not drive line related and have you inspected the shock bushings as well as the entire rear suspension?
Old 01-10-2011 | 08:08 AM
Hey Mike,
After I have accelerated from a stop and I reach my desired speed the gears seem to catch up an clunk. also at slow speeds (25 mph) yuo will feel it more often. I have speed bumps on the road I live on and you will hear it as you let off the gas and approach the speed bump. As for the drive line I haven't pulled the drive shaft to inspect as well as the rear suspension.
Old 01-10-2011 | 08:30 AM
hilltoppersx's Avatar
so the driveshaft was rebuilt with greasable u joints?
Old 01-10-2011 | 08:40 AM
Both front and rear have grease fittings.
Old 01-10-2011 | 09:49 AM
for the front shaft you should have 3 nipples (drive type) on the u joints and one flush on the slip shaft?
Old 01-10-2011 | 10:38 AM
Since you are new to Rover and are having problems, send me your number and I'll walk you thru a list of stuff to do/check.
Old 01-10-2011 | 11:13 AM
Just got out from under the LR and greased the front and rear drive shaft. 3 points on front shaft and 1 on rear.
Old 02-11-2011 | 04:54 PM
coors's Avatar
And...? Did the clunk stop. I'm getting under mine tomorrow to check for grease fittings. Just started to experience the same symptoms.
Old 02-11-2011 | 05:06 PM
coors's Avatar
just checked, no grease fittings on any of my u-joints (front or rear). I did notice a grease fitting on the rear drive-shaft and a grease fitting on the front drive-shaft although, no grease fitting was inserted in the hole.
Quick Reply: Clunk in the trunk
