Cluster Lights/Wiring Harness/Relay Question
I have a '97 and when I turn my headlights on the cluster and indicator lights go out. When the headlights are off the cluster and indicator lights work. I've found that this is related to fuse #8 blowing and when this happens my right rear taillights go out as well. I've read on here of this exact issue happening to someone and it was related to a ground issue located in one of the kicker panels. I PM the poster but have had no response. I removed both panels and am not having much luck finding a faulty ground visually. Does anyone have any insight as to where the ground for these connections are? I believe the glove box light is included also if this helps.
When I removed the right side (passenger) kicker panel I noticed a red connector coming from a bundled harness that appears to go to a relay. However there is no relay under there and some corrosion has started on the mysterious connector. Does anyone know what this should go to also? Thanks for any help Bryan |
if you could put a picture up of the mysterious connector with the corrosion that would help me understand what you are talking about, however I would start cleaning there, also I would go buy either a wire brush (either the tooth brush kind or the drill bit kind if you have a drill) and actually remove, clean (till the point that you have shiny silver metal) and reattach all of the ground points that you can find in each kick panel.
