Clutch issues
Old 02-17-2021 | 10:49 AM
lellylel's Avatar
5th Gear
Default Clutch issues
HI there,
Having trouble with the clutch in my Disco 2, sometimes I have to switch the engine off, and put is in gear start it with the clutch up and that seems to clear it.
What could this be?
Old 02-17-2021 | 11:10 AM
TimInNova's Avatar
Not sure about this, but in my old MX-5, there was a switch on the clutch pedal that the ECU used to make sure the clutch was pressed before it let the engine start. After 100K miles it wore out and had to be replaced.
Old 02-17-2021 | 11:54 AM
lellylel's Avatar
5th Gear
Thanks, not sure if there is a switch, will check the manual
Old 02-17-2021 | 02:02 PM
The Deputy's Avatar
Have you checked the fluid in the clutch master cylinder? Do you see any leakage from master or slave cylinders?
Could be adjustment, too. How much free-play do you have at the top of the pedal (amount of movement in pedal before you feel resistance). Should be a little under two inches of play.
If you have no free-play, adjust until you have desired amount.
Also, where does the clutch engage, when releasing pedal from floor? Should start grabbing at about the two inch mark from the floor
Old 02-17-2021 | 05:46 PM
Richard Gallant's Avatar
Lots of standards have idiot switch the clutch pedal, that requires it to be depressed to start the vehicle. Check the Rave
Old 02-19-2021 | 09:14 AM
lellylel's Avatar
5th Gear
Thank you so much... but would 'making the vehicle jolt forward',
by starting it in gear/with clutch engaged, fix a low fluids/worn clutch issue.
Feels more like SYNCRO, something in the way, that gets jolted back into position, for the rest of the journey
markdeg
11-28-2018 09:29 AM
Racoonatwork
04-27-2016 08:46 AM
diverjohn52
04-15-2011 11:29 AM
suveer
03-26-2007 01:47 PM
lugo35
Engine & Internal
12-13-2004 05:51 PM
Quick Reply: Clutch issues
