Code 1562
Does anyone know what code 1562 on a Discovery II is? thanks Phil
Download the Rave CD for more details.
P1562 (24) * Battery supply below 9V while engine running Effect: Maintains current gear in low range, limp home mode in range. Shift pressure to maximum, harsh gear shifts/engagement. |
An effect from your belt changing woes. It should not come back once you get your batt charged back up.
Again, you guys are the best. I cleared the code and it is running great. I gotta tell you, I had a very restless night! Now on to the driveshaft and I can take a breath. thanks again. Phil 2001 D II 75k miles, clean smog! 1999 D I 98k miles
Don't get too excited too quick, go clean and tighten your cables, then go get a free battery/alternator test done at your local auto parts store. I bet you will find something more then low voltage.
Let us know what you find. |
i am betting its a bad alt.,,, assuming your battery will not hold a charge
Come on guys, do your homework. :)
https://landroverforums.com/forum/sh...ad.php?t=24159 Once his battery is charged he will be fine. www.mechanicdoctor.com, bookmark it, it has all the codes. |
It appears that it was just the creative routing of the serpentine belt. Once corrected, all is good. Charging great and no codes, lights or weird electronics. Running great. Thanks for all of your help. I am in love again, yes Land Rover love is conditional. Phil
Fault Code 1562
Originally Posted by lipadj46
(Post 132060)
(Post 132060)
P1562
(24) * Battery supply below 9V while engine running Check alternator and also have the 150 amp mega fuse for the alternator checked. Both of those was bad on my '99 Rover. The fuse caused my new alternator not be able to charge the battery. It was reading under 9 volts. It is the big fuse in the fuse panel under the hood. I found a a new fuse for it at O'Reilly's auto parts store. Effect: Maintains current gear in low range, limp home mode in range. Shift pressure to maximum, harsh gear shifts/engagement. Fault Code 1562 |
