Code 1562
Old Aug 13, 2009 | 01:00 PM
ljdiscovery's Avatar
Default Code 1562
Does anyone know what code 1562 on a Discovery II is? thanks Phil
Old Aug 13, 2009 | 01:02 PM
lipadj46's Avatar
Download the Rave CD for more details.
P1562
(24) * Battery supply below 9V while engine running
Effect:
Maintains current gear in low range, limp
home mode in range. Shift pressure to
maximum, harsh gear shifts/engagement.
Old Aug 13, 2009 | 01:06 PM
whatmeworry?'s Avatar
An effect from your belt changing woes. It should not come back once you get your batt charged back up.
Old Aug 13, 2009 | 02:08 PM
Again, you guys are the best. I cleared the code and it is running great. I gotta tell you, I had a very restless night! Now on to the driveshaft and I can take a breath. thanks again. Phil 2001 D II 75k miles, clean smog! 1999 D I 98k miles
Old Aug 13, 2009 | 06:13 PM
Don't get too excited too quick, go clean and tighten your cables, then go get a free battery/alternator test done at your local auto parts store. I bet you will find something more then low voltage.
Let us know what you find.
Old Aug 13, 2009 | 06:16 PM
sloppyjoe's Avatar
i am betting its a bad alt.,,, assuming your battery will not hold a charge
Old Aug 13, 2009 | 07:42 PM
Come on guys, do your homework.
https://landroverforums.com/forum/sh...ad.php?t=24159
Once his battery is charged he will be fine.
www.mechanicdoctor.com, bookmark it, it has all the codes.
Old Aug 14, 2009 | 01:27 AM
It appears that it was just the creative routing of the serpentine belt. Once corrected, all is good. Charging great and no codes, lights or weird electronics. Running great. Thanks for all of your help. I am in love again, yes Land Rover love is conditional. Phil
Old Jul 19, 2017 | 08:18 PM
Joe30540's Avatar
Default Fault Code 1562
P1562
Check alternator and also have the 150 amp mega fuse for the alternator checked. Both of those was bad on my '99 Rover. The fuse caused my new alternator not be able to charge the battery. It was reading under 9 volts. It is the big fuse in the fuse panel under the hood. I found a a new fuse for it at O'Reilly's auto parts store.
Effect:
Fault Code 1562
hatt53
Mar 27, 2013 05:16 PM
pixel
Mar 5, 2012 12:29 PM
sayeedA
Nov 15, 2011 11:02 PM
markmckinney42
Nov 5, 2011 09:52 AM
