codes?
codes?
Is there an internet accessible place for the codes. I took the truck (96 discovery 4.0 168+K) to get it emissions checked. Came back with 7 codes, which I knew would happen , I got 8 on my reader. I was able to clear them all except the ever popular 1316. So, I just sea-foamed it and got new plugs and 7mm wires. After I cleared the codes and fixed the problem I got the 1316 after about 24 - 26 miles. Are 7mm good enough? Maybe I need to upgrade the plugs?
RE: codes?
P1372
1374
0300 - the report says: Random/Multiple Misfire Detected
0303 - Cyliinder 3 Misfire Detected
1316
1314
1313
the interesting thing I have found is that a few resources (including this forum) have resulted in a 1316 being for emissions yet, my reader says its related to 'manifacturer ignition system' I have noticed a passanger side exhaust leak at the connection of the manifold and the pipe.
1374
1316
1314
1313
RE: codes?
Well, I was able to take care of most of them. Now I can drive a while, and then throw it on the reader. All I get is the 1316 anymore. So I will clear them all out and go for a nice long spin, let the sea foam do its thing and see what comes up in the morning.
I bouth a new coil (two prongs) to replace the one associated with number 3 as I was thinking it was the faulty one. I will see what happens and hopefully dont need to install it and can get the 90 bucks back.
Oh Autolight is the wires and plugs. Advanceauto had them.
Grrrrrrrr
Just took it back to get tested and the same codes come up:
1313 and 1314 (which I now know are both cats, I guess I need new ones?)
1372 and 1374 ( coils do I need an entire new set or just the two?)
0300 ( I am thinking when the other stuff is fixed this will go away)
and now, a new one, 1193 (no idea)
So far I am thinking new cats and coil pack, is that about it?
