Coil Spring Conversion
Old Sep 28, 2011 | 04:16 PM
Rev Den's Avatar
7th Gear
Question Coil Spring Conversion
I was wondering if anyone had converted their air suspension to coil springs on Disco's with ACE? The RoversNorth catalog says not compatible for vehicles with ACE. My Disco is a 2003.
Old Sep 28, 2011 | 05:16 PM
rhyslegge's Avatar
Angry Ditching air bags.
I have a similar situation, haven't seen a kit yet, but can't figure out why. I'll keep searching.
Old Sep 28, 2011 | 07:34 PM
humroot's Avatar
I had mine converted for about a year (went back to air) and I had no issues at all. Pretty sure I bought the kit from Atlantic British.
Old Sep 28, 2011 | 07:38 PM
humroot's Avatar
http://www.roverparts.com/Parts/9268D2ABP.cfm
Doesn't say anything about not working with ACE. Did they tell you why its not compatible?
Old Sep 28, 2011 | 07:47 PM
Rev Den's Avatar
7th Gear
They said you would have to change front and rear sway bars and some other things?
Old Sep 28, 2011 | 08:34 PM
Rev Den's Avatar
7th Gear
Glad your's is working. I'll call British Atlantic tomorrow and see what they say.
Old Sep 29, 2011 | 09:05 AM
First, why are you wanting to get rid of that air suspension and second, yes you can convert but you will need to add 4 new shocks, coils and 2 rear coil seats.
Old Sep 29, 2011 | 10:26 AM
Rev Den's Avatar
7th Gear
I replaced the leaking air springs a year ago with Arnott air springs. Both sides have small pin holes leaks. Arnott said I had to send them back to cover under warranty. Can't be down with the vehicle that long. Also have replaced the compressor. Tired of messing with the air suspension.
Why do you have to replace the shocks at the same time?
Old Sep 29, 2011 | 07:30 PM
You do not need to replace everything at the same time, it is recommended but not necessary.
Buy the spring kit, install it and go.
Old Sep 30, 2011 | 06:21 AM
drowssap's Avatar
why not call Arnortt order new springs, when they arrive, ship Arnott the old spring and when they warrenty them just have then credit your account. that way you are not down any time and only have to carry the cost of the new springs on a credit card for a week to 10-days. If you remove the SLS you will most likely talk yourself into going with a at least 2 inch lift, which meens new springs, shocks, brakelines, ABS cable extension.
