Cold start clatter, whats normal?
Old 03-03-2011, 03:09 PM
94svt50's Avatar
Just got home from driving it all day and I noticed its pretty noisy when its hot at idle as well. Maybe I should switch back to dino oil? I dont remeber it being this noisy untill I went to the 5w-40 rotella synthetic, I also have the Mobil 1 301 filter.
Old 03-03-2011, 05:00 PM
yloDiscoII's Avatar
Originally Posted by 94svt50
Just wondering how much noise is normal on cold startup? When I start my '03 in the morning after it has sat all night it seems to make a lot of top end clatter for about 30 sec or so. When starting it warm or if it has been started recently it doesnt make any noise at all. The oil light goes out instantly upon startup maybe .5-1 sec. Im running rotella synthetic 5w-40 and the mobil 1 301 filter. And air temp doesnt seem to be much of a factor, seems about the same noise cold air or not. It seems more a product of sitting all night. Any thoughts? Do I need a heavier oil?
Thanks-jon
I run the same oil/filter setup as you and I have a little racket at startup, nothing I've ever thought to be abnormal, just needs a couple seconds to get the blood flowing.
I'd second Texmbr's recommendation of an oil press gauge since you've got an '03 and the fact that you're noticing that oil light staying on after startup, even if it's just a fraction of a second longer than the normal 'warning light check'.
Old 03-03-2011, 05:23 PM
94svt50's Avatar
The oil light really doesnt stay on, its the first light out on the dash.
Old 03-03-2011, 05:45 PM
94svt50's Avatar
Maybe IM just being too paranoid about this, I crawled under my toyota and pathfinder and they make noises to. It just seems the landrover is louder, maybe like a faint rattle mixed in, with kind of a chug, chug kind of a underlieing noise. This rover is going to drive me crazy maybe I should just sell it, listening for every little noise or some deviation from normal is really wearing on me.
Old 03-03-2011, 06:26 PM
yloDiscoII's Avatar
LOL. Just take the dang thing off road for a little while and all the paranoia will fade away, and you'll never want to sell it.....if only for a little while
Old 03-03-2011, 09:35 PM
Snafu / Disco Fries's Avatar
I do have to question why everyone uses the "wrong" filter for the truck. That is not the one recommended by M1 or anyone else. I looked at the two side by side, and made a few calls. Everything came back the same, "If it was better to use the different filter than M1 and others would recommend it." The two do have different patterns, and bigger is not always better. I'm in no way saying it is bad...just that I go with what is called for.
Old 03-04-2011, 05:21 AM
94svt50's Avatar
I just went off the sticky for the filter. Im starting to wonder If i have a small exhaust leak and that is the source for my noise. Above1500rpm or so the engine sounds great. Its just seemed a bit louder at idle, hot or cold for the last week or two.
Old 03-04-2011, 06:05 AM
Bundu's Avatar
Banned
Larger filter = more filtration area.
Old 03-04-2011, 10:25 AM
yloDiscoII's Avatar
^What he said^
Old 03-04-2011, 11:19 AM
94svt50's Avatar
I had two seperate mechanics have a listen to the rover, and they both said all the noises they heard were normal, with just a touch of valvetrain noise which seemed normal for a pushrod v8 with 102k miles on it. Also one said some of the chug, chug type noise might be from to low of an idle. When warm it idles down around 400 rpm, if you rev it to around 750 I no longer hear any noise.
Quick Reply: Cold start clatter, whats normal?
