It is the plug wire you changed. If it was on one of the ones that gets its signal for the timing it is the plug wire you changed. Try to change it before you take it anywhere. Let us know what the fix is regardless.
How many threads are there on this? I am confused, is it fixed, was it the MAF no plugged in?
Yes it works. The adaptive memory had to be reset. There are two threads, I copiled all my info into this one.
I was experiencing no power at times when accelerating, then I looked under the hood and the maf was unplugged. Plugged it back in and Ill see today. |
