Coolant leak in '03. Ignore it until I replace the engine?
I finally got around to looking about the intake when I remembered....
18 months ago, when I swapped plug wires, there was a bolt missing at the very back on the intake manifold. I suspect that the IM had been removed at some point and the PO never worried about putting a lost bolt back in.
Not thinking too much of it, I went to the hardware store and picked up another metric bolt to drop in its place.
I checked that very bolt and it has bottomed out 1/2" above being fully seated. I must have not bothered looking and stopped when it got tight.
Anyway, could this be the source of my coolant leak at the back of my engine (pax side, wet starter)?
If so, where can I find a replacement? Is it any different than the other intake bolts?
Edit: Just checking over the Rave manual. It looks like it doesn't have anything to do with coolant. It appears from the diagram that the 6 bolts only secure the upper manifold to the lower and no coolant flows between the two. So much for geting off easy
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
Victoria
04-09-2014 09:38 AM
