Coolant Leak Disco2
Coolant Leak Disco2
I have had a coolant leak on our Disco 2 (2000). Lately it has been getting worse. It seems to be coming from the back of the engine but I haven't investigated too closely due to temperature here in Canada.I understand there is a common coolant leak at the inlet manifold? I am trying to get an appointment at the delaer (looks like it won't get in until next week). Couldsomeone elaborate on possible cause and if a reasonable home mechanic could effect the repair?
much appreciated, Mike Hopton
RE: Coolant Leak Disco2
The most common coolant leak source on the intake we see on the Disco II is from what is called the throttle body heater plate --gasket. There is a kit to correct this. It is located on the underside of the throttle body with two rubber hoses connected to it. Typically , the coolant will drip onto the valve cover on that side ---and run down the back of the engine.
regards,
Geoman
www.eurotekapg.com
regards,
Geoman
www.eurotekapg.com
on
1 Post
Just had the job done last week by Ottawa Land Rover on my 2000 DII. It's apparently very common. The service manager explained that reason for this happening is that they did not use lock tight on the bolts at the factory, and also the bolts used would stretch due to the heat. So you could do the job yourself, but the dealer who changed all the surrounding gaskets, new bolts with lock tight etc... Did the job for $900.00.and you get a 1 year warranty on the job, parts and labor.
The gaskets, bolts and coolant will run you around $450.00 to $500.00.
Darover,
What currency are you expressing units in?........Jeez!....the kit costs $25 USD....and ittakes even the slowest mechanic in the world no more than 45 minutes to change it out.
Somebody really got slammed by the 'Stealership'.
Geoman
www.eurotekapg.com
Geoman
www.eurotekapg.com
I too have just experienced minor weapage of coolant. I only noticed it after topping off the coolant when I noticed it was low. It is not coming from the overflow tube. It appears to be dripping just behind the bumper on the passenger side. Any thoughts on the problem?
bookerbr
Model and year? Have a pressure test performed and look at the side tanks on the radiator. Coolant leaks from the front of the vehicle on a Land Rover are frequently traced to a radiator at the end of its service life ---and they start seeping. I would recommend you get this handled now, as Spring and Summer temps will just aggravate the situation and could lead to the dreaded overheating that is the death sentence for a Rover V-8.
regards,
Geoman
www.eurotekapg.com
regards,
Geoman
www.eurotekapg.com
The list price for a radiator is $550.00 ---add about $200 for labor. If the mileage is 75K or more, then also budget for a water pump replacement, which adds on another $400 parts and labor. Expensive.......but......a head gasket job is approx. $1800, and if it is overheated badly---- a engine changeout can cost $8K or more.
Sorry..........Just the harsh reality of the cost of Land Rover upkeep and the financial risks associatedwith putting it off until tomorrow.
Geoman
Geoman
