Coolant leak - how can I tell where?
Front cover, water pump, head gasket at the front or back edge, up at the valley gasket front or back, throttle body heater plate, expansion tank (check for cracks), check all hose connections.
A very good suggestion would be to go to Napa (call first so they can get it in from another store if necessary) and get a little bottle of coolant dye. You don't need a light as the dye is super bright.
ZMonet
06-24-2016 04:00 PM
