Coolant Leak Identification
Aye Aye Aye.
More degreaser and water hose. This time I did not see the same leak coming from the area of the front seal, but only along the driver's side of the oil pan. It looks runny, possibly coolant washing baked on oil away.
I think I've tracked the "wet" area up to the lower pulley area on the driver's side. The braided hose coming off the bottom of the PAS pump (if I'm looking at that right) did have coolant dripping down it, but I didn't think it had coolant in that area?
More thoughts or suggestions where to look next?
leaks
Throttle body could produce a small leak on bottom side that could leak down before its noticed. I had a leak on my my water pump gasket that leaked down almost exactly where your picture shows. Also might get you that mirror with telescoping lens so you can look down into spots hard to see.
I've already bypassed my throttle body heater. Everything on the top side (looking down) appears to be dry. I can only find wetness (coolant or oil) when I get underneath it.
The passenger side of the block near the water pump doesn't appear as bad as this side, but I'm ordering UV dye today. I plan on also buying some glowsticks and playing techno music while I look for the leak.
So I put the UV dye in it tonight and ran it for a bit before taking another look. It's still hard to tell, which I guess is a good thing since its a small leak. All the previous oil leaks have coolant in their drips (but no coolant is present when changing the oil). The front of the block below the drivers side head had slight UV coloring, but no standout drips.
I finally found the drip, but couldn't find it's exact source. It was running down the very front edge of the block on the drivers side from about the point of the exhaust manifold. I just couldn't see any higher and there is nothing at all when looking from the top down. Is it logical to assume this is the head gasket since the drip is on the far outside of the block?
robert.juric (07-20-2015)
