coolant level drop?
I was checking the fluid levels in the '03 about a week ago and noticed the coolant level was about 1/8" lower then two weeks prior. I checked it again this morning and it was unchanged from a week ago. On feb.16 I topped off the reservoir after getting it back from having headgaskets done and filled it up to just above the seam between the top and bottom of reservoir, which is slightly overfilled. So, a week ago when I checked it it was just level with the seam, about an 1/8 drop. Its somewhat close each time with the outside temps, and the vehicle has sat all night when I check the level. Am I just being paranoid and looking for stuff or could the head gasket job be failing.? Or do I need paranoid anonymous? "Hello my name is jon and I drive a landrover"
Hey Jon..first look for places it could be leaking, hoses, throttle body heater, around the heads and lower intake but first I would do a coolant system bleed to just make sure you have all the air out of the system. After a flush and bleed sometimes a little air hangs around in the system and works it's way out over a couple of weeks. If no air, no visable leaks I would return to who did it and have them pressure test or check your coolant for hydodarbons with a test kit. Do the obvious first. Look and check system for air.
I was wondering about air in the system, since the headgaskets where just done. The headgaskets where done by a small shop/carlot that just sells landrovers. The tech who did the job worked as a landrover tech for 10 years and did training for the new techs at one of the large landrover dealers in the area, so I am confident he could do the job well. Where can you get the hydrocarbon test at?
It's a go-no go test. The test strip will change color if you have hydrocarbons present. Also you can have someone cold start your truck while you have your nose next to the exhaust and see if you smeel the sweet smell of antifreeze. Not very scientific though. Correct way is a pressure test 15 pounds for 15 to 30 minutes or the test kit. Any milky oil on your stick or under the oil fill cap? But keep in mind a coolant leak does not have to be internal, it can be external at the heads or even the lower intake manifold also and not leaking into the combustion side of the motor. That why close inspection of the outside is very important. Get a cheap inspection mirror.
When looking for a powersteering gear box leak I could smell a faint coolant smell near top driverside of radiator. Oil looks fine. Im wondering if maybe it was air. I guess I could give it a couple more weeks, since the level hasnt changed any in the last week or so. But, I will give the hydro carbon test a try.
At the top driverside you have a small line coming off your radiator and returing under the cover over to the coolant tank. These get brittle and break, and also as said have a factory clamp on them. Worth pulling the fan cover and having a look see. I replace that plastic line with regular radiator hose on both my Disco's as they are prone to break. But since you have not had a coolant lose for awhile just top it off up to near the filler opening (but leave some space) and you can go from there. When I was having a leak issue I took a red grease pencil and marked my coolant level on the outside so I could see where it was. Mark at cold level, and check at cold level. Good luck.
