coolant out the back of the motor
Old 12-13-2014 | 09:49 AM
SkymonkeyONE's Avatar
I've got almost exactly 200,000 miles on my engine now and it seeps out the back as well. I'm happy just keeping it topped off seeing as how i'm going to have to replace or rebuild my engine at some point. As long as it runs fine and does not overheat, I'm cool with it. My truck runs GREAT, but I do have to park over a shallow drain pan to collect all the tranny fluid, oil, and other junk that leaks which I vigilantly keep topped off.
Chuck
Old 12-13-2014 | 05:40 PM
ls1morethanyou's Avatar
looks like my valley pan seal is really trashed, also looks like someone replaced the coil packs at one point. one has a yellow marking from like a salvage yard and the bolts on the lower intake manifold were hand tight.
Passenger side rockers and pushrods are out- loosed up the exhaust manifold bolts
official working on rover picture
Old 12-13-2014 | 05:42 PM
could this be the culprit? driver side rear. Still pulling heads because i am already here.
Old 12-14-2014 | 06:50 PM
zeroone's Avatar
I'll chime in as I just did the heads on mine saturday... thought I had 1 leak, turned out to be many. valley pan was the worst, it was pouring out of the thing. LS head was leaking in front, RS head was seeping in back.
That looks exactly like the marks on my lower manifold, when I peeled up the Valley pan, the 2 rubber end seals literally went to pieces.
Old 12-14-2014 | 08:31 PM
is rebuilding the injector orings and filter a good idea? the oring retainer was damaged on one.
also have to do spark plug wires. was thinking of buying two bosh kits and relocating the, to the top of the intake or remove them and so side and side(this will take some re wiring of the harness)
Old 12-14-2014 | 08:49 PM
zeroone's Avatar
I didn't touch the injectors or the filter. Left them on the manifold, I feel that I should have. Didn't buy a new PCV either(stupid me). I did change the wires though.. runs sooo much better.
Old 12-14-2014 | 08:50 PM
dusty1's Avatar
I messed with relocation
Not really a good fit, but doable.
Old 12-15-2014 | 08:13 AM
drowssap's Avatar
like this or this
Attached Thumbnails coolant out the back of the motor-coil-relocation.jpg   coolant out the back of the motor-img_2850.jpg
Old 11-02-2015 | 07:40 PM
chubbs878's Avatar
No conclusion. No help
Polo//S4
10-05-2012 07:22 PM
ColeRover
02-09-2011 07:05 AM
Quick Reply: coolant out the back of the motor
