Coolant overflow bottle cracked
Took the disco for a little off road jaunt, got to the car wash and looked everything over to discover that the overflow bottle is leaking from the bottom.
Is this a common occurrence or do I need to suspect excess pressure/heat? I had noticed a coolant smell and some coolant on the framerail the other day after hauling a trailer but racked it up to overfilling the coolant bottle (which I did) and spewing out the overflow tube.
Update us on what you find.
It's fairly common for the nipple to which the throttle body line attaches to fail. Here's what I did when that happened to me a couple years ago.
https://landroverforums.com/forum/di...-repair-67091/
I'm confident the field repair could have been a permanent solution although I eventually installed a replacement a couple months later that I bought on eBay.
New reservoirs are inexpensive and would recommend all D2 owners install a new one every ten years or so just as we should replace hoses as a PM item.
Thanks guys, I'll inspect it and see if it's just a hose. I dont suspect overheating as I literally just changed the thermostat to a white motorad and switched to green coolant witch dropped my Temps nearly 20 degrees, though I havnt had access to a scanner in several weeks and something could have very well happened since then. But I doubt it
Keep in mind it should be replaced regardless of what you find. Getting off $35 and spending <30 minutes now may save you time/expense of changing HGs or engine down the road.
Totally agree, although mine was a little more than double that price. Genuine Land Rover $80, not horrible as far as I'm concerned.
It was indeed the return nipple for the throttle body line that was leaking. I plugged the line and the hole in the tank until my new one gets here. Can't say I'm not a little disappointed in British plastic lol, my 1994 ford has similar miles and 10 years on my disco and it is only just recently beginning to show stress signs on the interior plastics. And my overflow bottle is pristine lol.
