Cooling system help!!! Leak
Merry Christmas all,
Heading out to do some wheeling with the family and cooling fluid is all over the ground. The bleed screw in the t section of the cooling pipes has cracked an coolant sprayed everywhere. No over heating, but is there a better part than the stock as I'd like to replace and not deal with it again.
Thanks in advance
Thanks in advance
Thanks again
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
You can use this brass one instead, it is more durable and will probably last the life of the truck. http://www.bmpdesign.com/product-exec/product_id/6857
