Cooling system troubles
#52
From my expierence, check everywhere there is a plastic fitting and be very careful, if it wasn’t the broken piece, it probably will be if you hit the wrong way or tighten a clamp too much.
As for monitoring temperatures I do it with a $15 dollar ELM327 obd wifi plug in and a $10 app (OBD Fusion) on my iPhone, it’s a little buggy but for the price couldn’t beat it.
#54
A common issue is that the screws that hold the plastic shroud over the radiator are two different lengths. Sometimes people who don't know that detail put the longer screw in the hole directly over that part of the radiator you are referring to. The longer screw is just long enough to poke that tiny hole.
jastutte (06-12-2018)
joshjellel
12-07-2016 02:50 AM
