Is this correct?
Old 04-17-2010 | 11:55 PM
XxRoverAllOverxX's Avatar
Default Is this correct?
If I were to purchase an OME lift kit that would replace the air suspension in the rear correct? Also what is the difference between the HD coils and the standard coils in terms of off road performance, stability, etc.?
Old 04-18-2010 | 05:53 AM
CopperMtnGuy's Avatar
I'm not too familiar with this specific kit, but I do know some about OME suspensions on Jeeps.
Since your getting the HD coils, it will sag a lot slower, and be more controlled in general, even off road. I don't want to say rougher, but because they are stiffer than stock, it'll be less bouncy.
Old 04-18-2010 | 07:48 AM
Do you want to lift your truck and keep the SLS, if so then for the rear buy an SLS spacer from RTE.
Old 04-18-2010 | 09:44 AM
I was thinking about losing the sls all togther and going with the HD coils in the back. How does the sls hold up off road?
shinyrover
06-30-2012 12:03 PM
christians1600
03-21-2008 11:18 AM
MONTANACW
02-02-2007 01:22 PM
Benhamtroll
06-01-2005 02:29 PM
Off Topic
02-25-2005 07:33 PM
Quick Reply: Is this correct?
