Couple of small things
My wipers work. But only if I turn them on before the headlights.
I tried to replace my rear wiper with a 14D, but the thing just wouldn't clip because the new wiper had too much material around where the arm is supposed to clip in. What brand do you guys use?
Last thing for now. I bought a cheesy FM tuner to play my iPod, but it sucks so bad that I'm gonna toss it. Is there any difficulties swapping the factory deck with an el cheapo aftermarket one? How can I tell if I have an amp or not? I assume only the alpine systems came with an amp from the factory, but I just wanna be sure so I'm not wasting money on this kinda stuff
If yours has an amp, it is under the drivers seat. you can't miss it. If it has a cd changer, it is below the passengers seat. Let me know and i can direct you to the harnesses that you need to buy. You can get a decent single din head unit that will fit nicely and not break your bank account.
Another alternative would be to get a Grom add-on. Just search Grom on this forum.
My stereo was able to accept a auxiliary iPod lead. Best I could do. Although 100X better than those FM boxes.
I used a Trico rear wiper blade that was similar to the OEM blade. I ran into the same problem that it wouldn't clip because the blade hit the arm. I used a dremel to remove a little bit of material from the arm so the readily available rear blades would fit.
Sure, I could have removed material from the blade, but if I'm on the road and something happens, I want to ba able to pull in to a parts store and slap it on, without having to first modify it.
That is good to know. I have aftermarket installed, so was throwing that out there, just in case.
The factory Alpine stereos will have the Alpine logo on the speaker grilles, right? Not entirely sure what I have because I have like a million speakers in this thing. It has a 6 disc changer under the passenger seat, but that's about all I could see through the tiny panel door
Factory speakers will only be labeled if HK(Harmon Kardon)
If it has amp, rear compartment door woofers, cd changer, it is most likely hi-line system with alpine head unit.
Aftermarket will require PAC-SWI(steering wheel controls), and harness adapter is Metra 70-1786(for factory amp), and there is a piece to fill in the blank space that will be under the aftermarket head unit(Metra 89-9400).
You will have two antenna leads(1 is large and 1 is small) and your choice it to use the larger end lead, or get a diversified antenna adapter that is basically a y-adapter(there is a company that makes one for the disco).
I went aftermarket, and removed the cd changer and installed mono bloc amp in its place to power 10" pioneer sub enclosure.
