Cruise Control
Old Mar 13, 2011 | 07:57 PM
Gerard's Avatar
Default Cruise Control
Hi,
My cruise control stopped working.
Where do i start.
Thanks
Gerard
Old Mar 13, 2011 | 08:17 PM
photocrimes's Avatar
Vacuum line on the bottom of the pump, passenger side fender well.
Old Mar 13, 2011 | 08:46 PM
Start at the brake pedal and follow the vacuum lines everywhere they go and check for leaks.
Old Mar 13, 2011 | 09:22 PM
Bundu's Avatar
Banned
D2 does not have a vacuum line at the brake pedal. Replace the vacuum lines at cruise control unit on the passenger finder.
Old Mar 13, 2011 | 10:24 PM
Thank you for the correction.
Old Mar 14, 2011 | 11:05 AM
Gerard's Avatar
Thanks for all your replies.
So, vacum line under passenger fender.....Is this accesssible from under the fender or do I have to raise the car up? Do I jsut replace the vacum line from one attachemnt point to the other and can this be done without having to raise the car?
Pls. advice...Repair tips willk help.
Thanks,
Gerard
Old Mar 14, 2011 | 11:07 AM
Bundu's Avatar
Banned
Not under fender... on top of the fender in the engine bay. Stand on the passenger side and look between the battery box/fuse box and the SAI pump (if you have SAI), you will see a small pump with some hoses. There is a cable running from the throttle body to the cruise control unit.
Evan5291
Nov 21, 2017 07:59 AM
37chambers
Oct 18, 2016 10:52 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
anonimaus
May 9, 2005 10:01 PM
flowers
Apr 12, 2005 04:03 PM
