Cruise Control
Old Apr 18, 2005 | 12:57 PM
UNCRover's Avatar
4th Gear
Default Cruise Control
Hello, I just purchased a 97 discovery with 60K miles and I have not been able to get the Cruise control to work. From what I understadn, you push the button on the lower left of the dash so the light comes on, then get to your desired speed and pull the set button on the steering wheel towards you. If I am not doing this correctly then please tell me, if not, then what could be the problem? Thanks.
Old Apr 19, 2005 | 05:07 AM
Jay's Avatar
Jay
3rd Gear
Default RE: Cruise Control
Sounds like you're doing it right. I have an 04 and you have to be going at least 28 mph for the cruise control to work. Are you going at least that fast when you attempt to set it?
Old Apr 19, 2005 | 12:56 PM
dogstarsix75's Avatar
Your doing it right. But it could be a bad cruise controler or loose wiring. The button on the consol does light up, right?
Old Apr 19, 2005 | 02:59 PM
mikemeyer0's Avatar
Mine does the same, as yours, i can hear the relay click so i know it is working that far, but maybe its a hose, i will wait and see what other people suggest.
Old Apr 19, 2005 | 05:45 PM
UNCRover's Avatar
4th Gear
Yes, I think I am doing it correctly (and over the 28mph min. speed requirement). It must not be working! Thanks..
Old Apr 19, 2005 | 11:29 PM
autigergp's Avatar
3rd Gear
Hey Let me know if you find out anything about your cruise control. I just bought a 2000 Disco II and mine won't set a speed after engaging the button with the light either, thanks!
Old Apr 20, 2005 | 09:58 PM
anonimaus's Avatar
Check the Vacuum tubing under the hood for cracks. It is frequently the source of your problem. It cost around $1.80 to replace all of it. Look for the actuator attached to the throttle cable, and trace out the lines from there to the firewall and vacuum pump. About 90% of the time it is the source of your problem. The other 10% of the time is a real bit*h to diagnose. I just recently had one of the 10% variety.
Old Jun 8, 2005 | 11:44 PM
dkelly13's Avatar
5th Gear
i have a 2001 disco and i have the same problem. i'll be moving along at any speed over the minimum, i'll engage the cruise control button (which lights the little light), and then i'll try to set the speed. nothing happens. i've checked the fuse, and it looks good.
what should i be looking for with the throttle cable and vacuum pump. i'm not very mechanically savvy at this time.
Old Jun 9, 2005 | 11:47 AM
msjulian's Avatar
5th Gear
I had the same issue with my '97 Disco I. I found that all the vacuum tubes were rotted. I replaced and it wrks great.
Old Jun 10, 2005 | 12:23 AM
Bait's Avatar
Do a search. I have posted a lot of info about this.
Evan5291
Nov 21, 2017 07:59 AM
37chambers
Oct 18, 2016 10:52 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
anonimaus
May 9, 2005 10:01 PM
flowers
Apr 12, 2005 04:03 PM
