Cruise Control Hunting
Old Aug 21, 2012 | 08:35 PM
Rover De Land's Avatar
Default Cruise Control Hunting
My 03 varies constantly while on cruise control no its not me and no it's not hills and no it's not normal. Thinking it was a vacuume leakI went to replace my vaccine lines as I have on all previous land rovers and found this one to be completely different. Finding only 1 replaceable line very short and nothing else.. Am I missing something and I already adjust throttle cable.
Old Aug 21, 2012 | 08:44 PM
There was a TSB on this, the cruise computer needed to be reprogrammed.
Call the dealer with your VIN# to see if it has been done.
Old Aug 21, 2012 | 09:13 PM
Ah thanks.. So a Tsb, that means I'll still have to pay for it?
Old Aug 21, 2012 | 09:35 PM
That depends on the dealer, some might do it out of the goodness of their heart, others will rape you.
Old Aug 22, 2012 | 06:48 AM
drowssap's Avatar
also check the rubber vacuum lines around the cruise controler (left fender)for dry wrought, it pretty common because of all the heat trapped under the hood
Old Aug 22, 2012 | 07:12 AM
Originally Posted by drowssap
also check the vacuum lines for dry wrought, it pretty common because of all the heat trapped under the hood
But.. ^ I...,,, uh.... ^
Old Aug 22, 2012 | 08:24 AM
drowssap's Avatar
Open the old post look at the picture find the actuator under the hood and check all the hoses for cracks or breaks https://landroverforums.com/forum/ge...l-hoses-51467/
Evan5291
Nov 21, 2017 07:59 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
Camdisco24
Sep 1, 2007 04:04 PM
MadBilly
Apr 27, 2006 02:37 AM
05LandRover
Off Topic
Jan 15, 2006 02:26 AM
