cruise control not working
Ok guys this is my next fix, my cruise doesn't seem to come on. I hit the button on the side of my instrument cluster and the green light comes on, but I can't actually set the speed. Before anyone asks, yes I was going more then 28 miles an hour.
Right Spike I did that, perhaps I wasn't clear. I press the button on the dash, then I accelerate to my desired speed with the gas pedal, then press the button on my steering wheel but it won't hold the speed.
I asked this question before I did a forum search, which is backwards. I got some ideas of where to look and then I had to go get water for a possible hurricane and visit the in-laws and now it's dark. So I'll look tomorrow.
Where inside the engine bay do I trace this vacuum line? I am one of those who live and die by cruise control so it would be 'most excellent' to try to fix it.
You try pulling it towards you on the steering wheel switch instead of pushing it to get the speed to stick?
________
Mitsubishi Galant Lambda
________
Start at the back of the brake pedal, there is a vacuum line on the back of the pedal, then just follow that, it will "T" in the engine bay, it cracks at the ends as the rubber gets old.
I used Liquid Tape and gooped up all of the ends of my cruise line and it has worked for 3 years now.
