cruise control problem
Old 03-28-2009, 05:32 PM
Originally Posted by mbmbbost
My cruise control stopped working right after I had the front prop shaft replaced by the dealer. Not knowing if there's a connection, I didn't go back. Might there be or is it just coincidence? I know on another vehicle I had, there was a speed sensor down in that area, but I have no idea with the Disco. I just want to be informed if I talk to the service guy.
Make sure that they didnt just turn the master power switch to the cruise control off.
I had my truck aligned after I bought it, took off on a trip the next day and no cruise for the first 150 miles, (the whole way there), on the way back...turned the power back on...cruise control...DOH!!
I have no idea why they turned the cruise off, but they did.
Check the simple things first.
Old 03-28-2009, 08:10 PM
mbmbbost's Avatar
4th Gear
Thanks for the reply. Are you talking about some switch other than the one on the dash? I think I hit all the simple things right off...fuse, etc..but if there's something else to check I'd love to know.
Old 03-28-2009, 09:25 PM
No, I mean the switch on the dash.
They had turned mine off, so the switch was not lit, I never turn it off so I didnt look at it.
If that is not it then it is probably a vacuum leak, very common.
Find all the cruise control vacuum lines and check for cracks, repair/replace as needed.
Start with the vacuum line that goes from the back of the brake light switch, follow it under the hood and to every where it goes.
Evan5291
11-21-2017 07:59 AM
southfloridadiscoII
06-28-2009 11:03 PM
whurst79
06-18-2008 06:51 PM
hanivw
04-23-2008 02:02 AM
totalperformance65
06-09-2006 04:58 PM
Quick Reply: cruise control problem
