Custom Bumper Fabrication - Mounting Question
Old Aug 10, 2013 | 12:28 AM
Francopacks's Avatar
Default Custom Bumper Fabrication - Mounting Question
I'm starting to work up some plans for a custom bumper to weld up and I'm wondering what the best way to mount the bumper to the frame would be (I'm, in the very beginning stages). Remove the crush cans and use:
A 2x4 square tube (3/16th thick) mounted inside the frame rail with 3 grade 8 bolts per side?
Or outside the frame rails with a bracket left and right of the rails with 3 grade 8 bolts per side?
I've been reading a bunch of build threads and have seen it done both ways.
I plan on putting a winch between the frame rails, so strength and rigidity will be important.
What do you guys think?
Old Aug 10, 2013 | 07:52 AM
Send me your e-mail address and I'll send you pictures of what I did and I doubt you will find anything stronger.
Old Aug 10, 2013 | 10:05 AM
dusty1's Avatar
i will post up some pics of mine after work today, should be easy to see, i took my bumper off last night. bent plate strap to sandwich the outsides and used original holes.
Old Aug 10, 2013 | 03:00 PM
dusty1's Avatar
recently, modeled these after the mounts, that i received with a previous disco bumper. original set up called for that angled inside support, have a 1.5 hole drilled in the bottom, for nut access. this time , I enlarged the holes and welded fixed nuts in. my winch is in bumper, though. I like the ease of loosening, but not removing the bolts, to lift off the bumper.
Attached Thumbnails Custom Bumper Fabrication - Mounting Question-dsc_6276.jpg   Custom Bumper Fabrication - Mounting Question-dsc_6278.jpg
Old Aug 12, 2013 | 06:58 PM
Thanks guys, I think I'll go with the outside!
Old Sep 14, 2020 | 02:55 AM
mohamey's Avatar
Hello,
I just joined the group and have a 2002 Discovery and looking to build a front bumper using my Fabrication Shop. Can you please send me any build information on the same to mohd.yasir.kv@gmail.com
LRlax11
Apr 26, 2015 02:13 PM
bosshogt
Aug 12, 2013 08:01 PM
bigcraigman
May 21, 2013 11:33 AM
whall85
Dec 13, 2012 02:18 AM
ATXDisco
Nov 18, 2010 08:40 AM
