Cylinder #4 Misfire
Hi all,
A quick question about a service engine soon light activation. The other day when I started the LR it ran rough for a few moments and the light came on. Its run fine since then. This also happened a few years ago and it was my intro to the 1500.00 LR major tune up, LOL. I had the same service done locally for 700, w/o the coils. I subsequently picked up a new set on ebay and have them ready to go in if necessary.
I just picked up an OBD II scanner and used it for the first time, thats where I got the cyl 4 misfire. I saved all the readings and cleared the code. I then checked the wires, all looks good.
My intention is to let things be and see if the code comes back, any downside to this approach? If it does, I plan on breaking out the FSM and doing the coils, wires (I know magnacore) and plugs myself.
Just a thought I also like to run by you guys, any chance this could be caused by humidity/moisture. Its been raining heavily and humid as hell lately and IIRC the last time this happened the same conditions existed. The LR was sitting for a few days when it happened.
Thanks
Oops, 04 Discovery with 65K
Thanks
Not sure if humidity/moisture could cause it, but I just found out the hard way that misfires can be caused in a hurry by crappy wires.
I replaced my wires with some off-brand about a year ago (only put about 7,000-8,000 miles on the car since then, if that), and just last weekend, I started running really rough (the term "running" used very loosely). Flashing SES light, etc. The truck started by a little rough idling the day before to being barely driveable the following day.
I decided to try replacing the wires with something better first. I replaced my "Allmakes" 7mm's with some Kingsborne 8's. Problem solved. The whole thing cost me $48 and about 2 hours. Would have been much faster if I hadn't taken so many breaks (it was hot out).
When I removed the old wires, they looked fine. Didn't see much wear on them. I was worried when I saw that, because I thought the problem might be elsewhere... like the coil packs. But the new wires did the trick. Did the job yesterday. Drove the truck 30 miles to the hospital where I work (I'm a 2nd-year med student) this morning. It runs beautifully.
Oh, also, I think sometimes, you can just get a random misfire from the truck. When I first got it (used '02 disco II, with about the same mileage as is on yours), that happened. It sputtered and the light flashed and I freaked out. At the time, I was a poor student who had just flushed his credit down the toilet to return to school to do my med school pre-requisites, and I knew nothing about working on engines either. The problem went away on its own and no problems until last summer when I had to do my tune-up.
Before I changed my wires my truck would misfire terribly on wet rainy mornings. I bet the new wires will cure your situation. Magnacors are $85 from Apex Performance best price you will find anywhere. If the is too rich for your blood people have reported to have god luck with kingsborne 8mm wires.
on
