cylinder 8 misfire
I would check cylinders around #8 and then see if #8 is in that range.
I would not ever bother tho.
Your symptoms are classic head gasket
OK so checklist:
1) Gurgling water fall sound on accelerate from a stop light: yes or no?
2) Coolant level falls and then rises after you stop the truck and take the cap off - yes or no
3) Misfire on 1,2,7,8
All these are HG issues.
OK so checklist:
OK so checklist:
>> no
>> yes
>> no, misfire only on cylinder 8
OK so checklist:
>> no
>> yes
how to test radiator cap?
I'm wondering my radiator cap still holds 14psi, how do I test radiator cap? I see coolant out from the tank breathing tube sometimes, is this normal?
Man up and pull the heads.
Wishful thinking will not fix the truck.
I did the same thing for a few weeks.
White smoke - I had SOME.
Put in Barr's leaks and it went away.
Coolant LOSS - I had some
Hose pressure - I had a lot.
Misfile on Cylinder #1.
YOU have a crank in the head gasket between the water jacket
and the cylinder on #8. The crack is 1mm by .01 mm.
And, that's it.
Get to it.
Your life is going by and you are fretting.
Just deal with it.
Flickr: Landroverdude2's Photostream
And, that's it.
Get to it.
Just deal with it.
crank typo
Should be crack.
Look at the spent head gasket on my pictures for the crack.
See if you can find it.
I can see it on one of my flickr pictures.
You'll undoubtly have that same crack.
Like old shoes the gaskets wear out.
Pull it apart and then you can brag about finding the crack and fixing it.
Should be crack.
