D2 Rust - Common Problem Areas
Now that I've looked a couple of Michigan vehicles I really need to know the hidden places and trouble areas for rust on D2's. I should probably be looking for a southern vehicle, but there are a couple here in Michigan that have seen limited winter use, or so I am told by their owners
I did a search and found some info on the rear frame rails, but what are the other spots do I need to look for?
thanks in advance!
thanks in advance!
As far as I know it mostly the frame. The rear frame rails as you found. Behind the cats up front are the two spots I know but I would check the whole thing. I got mine from down south and had almost zero rust when I got it, but after two New England winters I already have to hit it with some corroseal.
Spencerfitch
05-03-2010 02:56 PM
traffictech870
02-06-2008 12:12 AM
