This is the Disco 2 forum. So while some folks will likely try to help, you are better off starting a new thread in the LR4 subforum.
"Once you replace the cable lube the latch and cable every 6 months with silicone spray, do this to ALL moving parts on your truck, locks, latches, hinges...everything.
If it moves it needs to be lubed." Hilarious. |
Thanks for the quick reply mr mordo and frank... Yes the Discovery2 the predecessor to the LR4 has a similar design. I posted to the thread because of problem description. I have post in the LR4 section as well. Funny I have greased the latch less than 6 months ago but maybe not all spots or alignment problem or in the LR4 there are 2, maybe second cable? but do like the Forum like response.
