Dashboard bended
Old Feb 10, 2006 | 01:24 PM
marcolanza's Avatar
7th Gear
Default Dashboard bended
I have got a 1995 Discovery 2.5 TD.
The car is having the dasboard heavily bended up at the front (near the windshield). Probably doe to the heat.
Somebody told this was a fault for which this model has been recalled when new for replacement.
Does anybody have the same problem?
Thanks
Old Feb 10, 2006 | 01:33 PM
NHESS81's Avatar
Default RE: Dashboard bended
Yes, this is a known issue. I am pretty sure you can no longer get it replaced under warranty, if they ever did. You could call your local Land Rover dealer and see if they will replace it. It is always harder to get things fixed on 10+ year old cars. I hope you can find a solution. http://www.landroverworld.org/forums...highlight=dash This discussion might help. Gives ideas on quick solutions, as well as a parts supplier for a repair kit...good luck!
Old Feb 13, 2006 | 02:03 PM
marcolanza's Avatar
7th Gear
Thanks NHESS81, but what should I replace with the **** in the address that you gave me?
Old Feb 13, 2006 | 10:07 PM
NHESS81's Avatar
land rover world .org but no spaces...this message board censors stuff wierd
Old Feb 19, 2006 | 03:10 PM
Biggles's Avatar
3rd Gear
I had the same problem with my wife's 95 Disco. Fortunately there is an aftermarket product which you can lay over the riased edges and screw down. Unfortunately it is much easier to achieve when the winshield is removed but it can be done without.
frearson
Defender
Jul 31, 2007 11:05 AM
jonnymcd
Jul 25, 2007 03:11 AM
A12LR3
Mar 22, 2007 06:32 PM
StephenK1706
Audio/Visual Electronics
May 24, 2005 12:03 AM
rover11
Appearance & Camping Set Ups
Apr 5, 2005 08:42 PM
