-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Deck the heads? (https://landroverforums.com/forum/discovery-ii-18/deck-heads-58069/)
pinkytoe69 Apr 1, 2013 01:51 PM
Deck the heads?
Ok, got a call from the machine shop about the heads from the cracked block D2.
One is 5 thousandths off and one is 7 thousandths off.
Is it worth paying the $100 to have them done?
ZGPhoto Apr 1, 2013 02:02 PM
I paid $400 to have mine done..so...yes do it.
pinkytoe69 Apr 1, 2013 02:08 PM
I mean is it worth it in the sense that they are being installed on a cracked block.
ZGPhoto Apr 1, 2013 02:23 PM
You're going to be running a cracked block?
pinkytoe69 Apr 1, 2013 02:33 PM
Hopefully, yeah :)
Previous threads...
https://landroverforums.com/forum/di...-please-57855/
https://landroverforums.com/forum/di...d-right-57996/
ZGPhoto Apr 1, 2013 02:40 PM
Ooh... well I don't want to give suggestions that may negatively affect your rebuild. Sometimes two damaged things just work better together. Good luck!
pinkytoe69 Apr 1, 2013 03:31 PM
*sigh*
Ill just go ahead and do it.
Its only money right?
ZGPhoto Apr 1, 2013 03:33 PM
It is only money!
jfall Apr 1, 2013 03:37 PM
block and heads may be warped the same way..
So,maybe not do the heads and put them back on.
As long as you can put left on left and right on right, right?
