Definitly OCD.
My recently purchased LR 02 Discoveryll 55k,Replacement for my dearly Loved 1995 Mitsubishi Montero SR(which I still own)
I have changed the oil 4 times in less than 1000 miles, I can not make up my mind. In the Montero I used Chevron supreme synthetic 10w-30 and Delo-400 0w-30 synthetic since 2002 (filter choice was Nippon & Mitsu original)when I had the Motor rebuilt @77K. It has 98K on it now in 2008. The Discovery came with fresh oil from the Toyata dealer I purchased it from (mobile Clean 5000 5W-30 and a napa filter) Firstchange was penzoil Platium10W-30(landRover filter) Second change Penzoil Platium 5W-50(Crosland, filter) Thirdchange was Chevron Delo-400 15W-40(Bosch filter) Forth and finalchange chevron Delo-400 5W-40 synthetic(LandRover filter) OkI have issues yes,but I finally feel like I made it to the correct choice for me and My Disco. I have 3 LandRover filters Part#ER3340 in stock and 6 Gallons of the Delo-400 5W-40 so I have a commitment now. I have pretty much completedall of the 60 k service as recomended by the Rave CD 1.Flushed the Break fluid(used Land rover fluid) 2.Flushed the power steering 3 times (used LandRover fluid) 3.Changed the Trans fluid(Used penzoil Multi ATF) 4.Changed all the Diffs including the transfer case(Used Redline MT 75-90) 5.Changed the Plugs(Used NKG Platiums) wires are on the way(land rover Part) 6.Changed the Thermostat(Used land rover Part) 7.Changed the coolant(Used Dexcool original) And the list go's on. I have schrubed the under side with engine cleaner and break clean with a Tooth brush and rag(removing grease spots and what not. Yes I am still Married. |
RE: Definitly OCD.
Wow, sounds like you got it figured out now. I think your screen name is fitting, you're all over the place. :DYour engine must be flushed pretty clean now too. I know exactly how you feel though, I was all over the place on engine oils when I first got my truck and I still haven't settled on anything yet. Land Rover owners seem to use just about every different weight of oil that ismade. Your wife is a saint and by the way, you'll probably change you mind again soon.
