Diagnosing cooling issue
Be sure to check the condenser fan it is pretty common to have them freeze up.
I also own a 2003 that I got exactly 1 year ago and within the first month every single piece and part of the cooling system broke/faulted or was on its way out. I mean even the plastic lines. Replace EVERYTHING and refill it with the green ethylene-type antifreeze, distilled water, and a whole serving of coolant additive (it works.) Even all of the small rubber hose connecting the plastic lines at the radiator/tank/manifold needs to be updated with new hose and run it directly to point-B where the factory plastic pipes went. Those 210+ temps with DexCool corroded everything from the inside. The AC fan will do nothing for your operating temps but it needs to be in working order nonetheless. Having been there and done that, just update everything on the coolant system because it's all **** from the inside, out.
This tube is shown exiting upper/driver side radiator, routed behind ancillaries over to the tank. Will last forever with no opportunity for leakage or breakage to occur. There are enough quirks in the cooling system to deal with before having to worry about plastic pipes corroding and snapping leaving you stranded.
1. At 60 mph, transmission in Drive, tach at 2000 rpm the temp reported by the ECU via an OBD II device is 217 F.
2. At 60 mph, transmission in 3rd, tach at 3000 rpm, ECU reports 206 F.
So higher RPMs, but same forward speed and ambient temp, and I get a lower coolant temp....
Both at 60 MPH, the power developed by the engine is the same. Fuel consumption, wind resistance, friction are very nearly the same.
But in 3rd gear, the water pump is moving more coolant mass and cooling more because turns at a higher rpm.
iceray111
05-15-2010 02:40 PM
