diff lock
RE: diff lock
All DIs come with a CDL (thats 94 to mid 99). DIIs the only year I'm positive does is 04, and I think 00 and 01? Maybe? Regardless you would probably want to consider avoiding 03s because of the oil pump failure (do a search for it, there's plenty of info on it)
The diff lock is just the center diff in all models, but it's easy to change out your front and rear diffs for locking diffs.
RE: diff lock
ORIGINAL: pilsner
so i see that my 2000 disco II has a CDL but how do i activate it?
and is there an aftermarket setup that works in a slick and efficient manner?
thanks
thanks
RE: diff lock
Since LR no longer makes the '04 linkage, Ashcroft (yes, the same UK company that does the transmissions and axles) is about to release their own version to engage the CDL in about 2 weeks. I have not seen pics, so I don't know how it works. D2's 1999-2001 (mid -year) have the CDL in the t-case. If you need to engage it before getting the linkage, crawl underneath with a 10mm wrench. Wear long sleeves cause of the heat and turn the nipple about 45*.
RE: diff lock
Here is Ashcroft's site. I checked there, but haven't seen anything yet about their CDL, just the '04. I heard about it on DWeb from someone that works at Ashcroft. Here's a link to some pics of my install. UrbanPanzer has a great write-up, which I used for my install. Go to Discovery2.co.uk. The CDL is not a diff locker like an ARB or Detroit. It locks the center diff (the t-case) so there is equal torque output to the front and rear axles. If a tire is spinning (while the CDL is locked) on both the front and rear axles you'll be stuck. If the CDL is unlocked you only need one tire spinning to get stuck. Having lockers on each axle (ARB) gives you the option to drive all 4 wheels, regarless of the traction each has.
