diff lock
RE: diff lock
I have an 01 and am getting ready to put a DI shifter in. Here is a link that will explain the procedure. You can pick up the DI linkage from e-Bay for about $150 delivered.
http://www.lrrforums.com/showthread.php?p=37176
RE: diff lock
The t-case lock (CDL) is within the t-case itself. It distributes power 50/50 front and rear when locked, so if a tire spins on the front axle, the rear will still get power to get through the obstacle. If the CDL is unlocked and a wheel spins, all of the power will follow the path of least resistance which means the tire without traction will just spin.
A "locker" usually refers to mechanical parts inside the diff/3rd member/pumpkin on the axle. There are different types that work in different ways, but bascially they lock both wheels (on the same axle) to spin at exactly the same rate. So if you have lockers front and rear, you can have 3 tires spinning and the one with traction can still pull the truck.
Watch this video. It's one of the best exlanations as to how differentials work. It's a moldy oldy but applies as much today as it did in 1937.
RE: diff lock
YOur hi-lo shifter is also your CDL shifter, move it to the left and your CDL is locked in Hi, move it left and then forward and your CDL is locked in Lo.
So there is no extra shifter to install, just the linkage which is under the truck.
Connect the linkage from the t-case to the shifter and you are good to go.
RE: diff lock
