diff lock
i have a 96 disco, automatic, gas., When off roading and diff lock is engaged only the two back and one front wheel are turning when slipping in the mud, ect. From my 4x4 expirience i assumed diff-lock meant the axles were locked and all 4 wheels spun at the same rate. After reading the manual it said the difflock locked the front and rear drive shafts so that they spin equally. This was unfarmiliar to me and almost sounded like there was some kind of locker in the transfer case. This is my first rover so i am somewhat unfarmiliar with the 4x4 system. so is my diff-lock workin correctly or is somethin faulty
thanks
-anthony
thanks
-anthony
Anthony,
You are correct. Difflock locks the transfer case. Meaning both drive shafts spin equally. So, you can have one front and one rear wheel spinning in difflock. Yes the term is misleading. Some people have differential locks installed which would make all four wheels turn. This is only necessary for extreme off-roading. Your stock set-up works quite well.
Bait
Bait
Don't forget there are actually 3 differentials in a land rover. At the transfer care ( i believe this is the one you are referring to), commonly known as a centre diff lock. There are also differentials at the front and rear axles. These can also have diff locks fitted, though uncommon for any but hard core to get a front diff lock fitted.
on
Anthony,
Other then the new Rubicon, no manufacture has made a vehicle that will lock all four wheels. Most jeeps have open diffs as do many others unless installed as an option.
If you want power to all four wheels, as already mentioned, you'll need to install front and rear lockers. If you were to do this, you would need HD axles, most liokely gears and some form of a locker like an ARB, Detroit of TrueTrac, costing in excess of $3000 for all.
Anthony,
So does the Rubicon. The power wagon is a fully loaded 2500 Ram. But I am not sure you can have the cummins engine in the power wagon. Anyways I still think the 2009 Ram 1500 looks better than the 2500. They didn't change the 2500 model yet.
