difference in series II models
Not really a tech. question, more of a curiosity.
Could someone give me a quick rundown of the differeces in models?
I have seen:
Plan Disco’s (no lettering)
SD models
SE models
LE models
HSE models
I have seen:
SD models
SE models
LE models
HSE models
In the 2000 to 2004 years you had S (base model, no badge), SE (mid range model) and HSE (high end model).
Prior years had something like L, LE and LSE - I'm not exactly sure on what they were, but you get the idea.
7 seater models have a 7 tagged on, like SE7, HSE7.
Correction: model badges changed almost each year.
1994-1995: no badges, but there were 2 models
1996-1997: SD, SE, SE7
1998: LE, LSE
1999 I: SD
1999-2000: there were 2 models, but not clear on badges
2001: SD, LE, SE
2002: S, SE
2003-2004: S, SE, HSE
1998: LE, LSE
1999 I: SD
2001: SD, LE, SE
2002: S, SE
Dam limey's can make anything easy can they? it's like play with alphabet soup.
I give up; it took me 20-years to figure out Harley's alphabet, I dont have another 20 to give to Land rover.
Thanks Bundu
Thanks Bundu
I have a 02 SD and a 01 SE. SD are base models with duragrain interior (not leather), base radio (no remote amp or cd changer), no sunroofs/moonroofs, no class III hitch, while the SE has there items. With a SE the sunroof was an option so you will find some without. The SE has alpine radio with external amp at 220 watts I think. The HSE model had Harmon Kardon with 330 watt amp. Of course SE and and HSE had the 7 option. Rear area seats. SLS and ACE was available option on both the SE and HSE.
here is why I was wondering I have a 2000 w/o badging that is a factory 7 passenger vehicle, with ACE, SLS, dual sun roofs, rear A/C, hitch and folding step, leather and a Harmon Karon Stereo (i believe and Alpine head unit) & 18 inch wheels. Could you order all these options on a base model it seem at some point with these options you would have stepped out of a base model OR was the front clipped and the never replaced the decals? I guessing the front was clipped.
Sounds like someone pulled the badge's off a SE7. Some of the options were not available on the SD...like ACE and SLS..heated seats ect. Sunroofs yes, and upgraded entertainment. Stereo's were a dealer option.
Not sure if it helps, but from what i have found out my 2004 SE has every option except third row seating although i have vents back there and rear controls for options. THis being the case i am not sure the badges mean much if the truck was ordered to fit particular needs of the original buyer.
