differences between 4.0 and 4.6?
There seems to be quite a few 4.0 still out there running with high miles. What are the differences between the 4.0 and the 4.6? Is it just the same engine with a touch more displacment? Obviously, the 4.6 may attain the same longevity its just not old enough to be there yet.
thanks.
thanks.
Thanks. Actually there is a good bit of overlap, pretty much all the same bearings and timing chain parts. The real difference is in the piston assembly and connecting rods, which you would expect being the extra displacment.
You should be able to swap it right over, no need to update the crankshaft sensor (but I think you mean camshaft sensor, which shouldn’t need to be changed either).
