Different shocks because of ACE?
Old Jan 26, 2011 | 09:21 AM
DiscoIIBrandon's Avatar
Default Different shocks because of ACE?
Hey guys, just wondering if there is a difference in shocks on vehicles with ACE? I ask, because i've seen some shocks listed as "for vehicles w/out ACE", etc.
If so, I'm assuming only the rear shocks would be different? And what's the difference, longer? Shorter?
Thanks.
Old Jan 26, 2011 | 11:25 AM
Jabez's Avatar
Default Good question
If I remember correctly it is length and it not much so standard shocks would just limit travel.
Since you are in the market as I was 2 yrs ago I will pass on a very good recommendation I received from some people on this forum.
Do the springs with the shocks.
Rovertym's spring and shock kit (Rovertym custom springs -Old man Emu shocks) is an excellent product. Will give you a little lift if you are looking for it without requiring brake hose extension.
Old Jan 26, 2011 | 11:39 AM
Yeah, i've gotten nothing but uncertainty so far. Atlantic British says "yes you need different shocks to fit ACE system" and then when asked why or what the difference was they said "Not sure what exaclty is different but all of the manufactures have listings without ace so there must be a solid reason, either fitment or ride quality".
I've also heard from another parts source that said the shocks are the same confidently, but then went on to say, well, we've put the regular shocks on many ACE fitted vehicles with no problems.
I was just curious if anyone actually knew the real scoop, since there seems to be uncertainty. I couldn't tell of any difference between my original shocks and the standard sized I already put on (its my wifes ride and she didn't want a lift!) And i've taken the advice of doing the springs as well, thanks!
Old Jan 26, 2011 | 11:59 AM
Jabez's Avatar
Default Rovertym knows
You can call the guys at Rovertym. I had the same deal with lack of info and the Rovertym gents had a specific technical answer; I believe they gave me a number that was the difference in length in inches.
Very knowledgeable and very helpful.
Old Jan 26, 2011 | 12:06 PM
photocrimes's Avatar
My guess would be that the shocks are valved different to allow the ACE to function more efficiently. Fit may be identical, no physical difference.
Tin_Man
Apr 12, 2014 11:12 AM
thehrdway
Apr 26, 2011 01:41 PM
tbuckt007
Apr 13, 2010 11:46 AM
javoli001
Jun 3, 2008 10:18 AM
alrd
Nov 17, 2006 11:25 AM
