DII Cargo Door Subwoofer
Hey Guys,
I can't find a cargo-door subwoofer on RoverParts.com... any idea where I can pick on of these babies up? The one in the 2000 blew.
Thanks!
Pat
PS_ I also need a right front speaker for the bottom driver's door for my 2004. That has some Sub-Woofing capabilities, and it's rattling a bit. I think it might be blown.
Thanks!
Pat
Hey guys- I also need a stabilizer bar- is this "that"?
http://www.roverparts.com/Parts/6497D2.cfm
THANKS SO MUCH!
THANKS SO MUCH!
i replaced my original subs with some new ones from audiobahn but i had to do some trimming as the magnets on the OME harmon kardons are really tiny. they sounded great when i installed them. now i took them out completley because i installed stainless steel back there instead. i would reccomend upgrading the speakers rather than your other options. one would be buying the replacement from the dealer which is expensive or buying used from a junked vehicle which isnt that smart because its just as old as what you had in there and won't last long...
as for the steering damper, how do you know yours needs replacement?
Well, I assume it's got to be the steering shock absorber thing... the vehicle is aligned perfectly, and it cruises at 85mph perfectly smooth. And if you jack it up, the front wheels are tight!
BUT- when you hit bumps or potholes, it jerks you from side to side.
What website did you order that sub from?
THANK YOU so much for the information man.. you're a good pal!
Hey adam, I'm looking to get that stainless panel on my door as well. Do you just get rid of the sub all together? I was looking at it on the website and was like... somethings missing there...
