disabling ABS
Old Jul 19, 2008 | 01:45 PM
alemurill's Avatar
Default disabling ABS
Hi all,
Discovery 96, V8, 4.0L
I need to disable the ABS temporarily. Which fuses/relays would I have to remove?
Is there anything else I have to do?
Thanks a lot,
Old Jul 19, 2008 | 03:07 PM
Default RE: disabling ABS
Open the hood, the fuse box on the left fender there is a fuse maked ABS, pull that fuse and save it for later use. You are done. The ABS light will come on on the dash, but thats all, you are good to go.
Old Jul 19, 2008 | 03:14 PM
On second thought, it might not be marked in the fuse box, check your owners manual, it will tell you what number fuse it is, but you pull the one from under the hood,NOT under the dash.
Old Jul 19, 2008 | 06:13 PM
alemurill's Avatar
Hi Spike,
There are three ABS fuses according to my owners manual.
Two in the fuse box in the engine compartment (ABS pump & ABS valve) and one under the dash.
Should I disconnecto the ABS pump & ABS valve fuses only?
Thanks,
Old Jul 19, 2008 | 08:59 PM
I have a '97 so it should be the same fuse box, tommorrow when it is daylight I will see what fuse I pulled on mine. I only pulled one fuse though.
Old Jul 20, 2008 | 09:57 AM
I only have one ABS fuse under the hood, 30A, ABS Valve. That is the one I pulled.The cover on the under hood fuse box is labeled with the fuse name and amperage.
Old Jul 21, 2008 | 11:02 AM
alemurill's Avatar
cool.. thx
Robover01
Nov 3, 2021 06:31 PM
jeff spahn
May 3, 2012 09:18 AM
shaka khan
May 31, 2010 12:08 PM
CopperMtnGuy
Mar 17, 2010 06:22 AM
goldfishy
Dec 12, 2008 12:13 PM
