Disco 2 will not drive only reverse
2000 disco 2 ,,1270 miles , no codes ,,,changed atf truck only go in reverse will not drive
Did you get the fluid properly topped off?
4HP22s are very hardy transmissions.. the only way this could happen after JUST a oil change is if you forgot to fill it, tried driving it, and filled it. Being that it doesn't move.. Clutch B failure and your pump is soon to follow, rendering the vehicle immobile.
but, what is the full story? |
Did you also change the transmission filter? If so, sometimes transmissions take multiple drains+refills before they are good to go again.
Originally Posted by John073
(Post 661927)
(Post 661930)
Originally Posted by No Doubt
(Post 662002)
Originally Posted by User
(Post 661984)
What was the problem?
Probably front clutch gone out, it happens on HP22's
