Disco 2 will not drive only reverse
Old Sep 14, 2018 | 10:31 AM
John073's Avatar
4th Gear
Default Disco 2 will not drive only reverse
2000 disco 2 ,,1270 miles , no codes ,,,changed atf truck only go in reverse will not drive
Old Sep 14, 2018 | 10:48 AM
Did you get the fluid properly topped off?
Old Sep 14, 2018 | 07:44 PM
User's Avatar
4HP22s are very hardy transmissions.. the only way this could happen after JUST a oil change is if you forgot to fill it, tried driving it, and filled it. Being that it doesn't move.. Clutch B failure and your pump is soon to follow, rendering the vehicle immobile.
but, what is the full story?
Old Sep 14, 2018 | 09:53 PM
No Doubt's Avatar
Did you also change the transmission filter? If so, sometimes transmissions take multiple drains+refills before they are good to go again.
Old Sep 16, 2018 | 08:47 AM
John073's Avatar
4th Gear
yesdid everything by the book
Old Sep 16, 2018 | 08:49 AM
John073's Avatar
4th Gear
i did not repeat the atf refill. A lil info on the truck,,,2000 disco 2,,1270 miles.
Old Sep 16, 2018 | 09:41 AM
John073's Avatar
4th Gear
full story,,,2000 disco 2, 1270 miles, tyranny was slipping, then stop moving in drive, or reverse. Change atf and filter. Topped off,will only go in reverse. Lights indicate truck in d, rpm goes up a hair when put in drive. Reverse work
Old Mar 15, 2024 | 04:52 PM
Broken08's Avatar
What was the problem?
Old Mar 15, 2024 | 06:46 PM
Extinct's Avatar
Probably front clutch gone out, it happens on HP22's
Adamdisco1
Jul 28, 2017 02:50 PM
Gromeo
Jan 11, 2017 11:39 AM
MuleyJ
Aug 19, 2012 08:02 PM
treant985
Dec 27, 2010 02:51 PM
loic
Jul 8, 2008 05:22 PM
