Disco II-didn't buy and happy
Hi guys, I checked in here about a month ago when I was looking at a used Discovery II. The huge amount of maintenance was the decideing factor for me.
Anyway I bought a Grand Cherokee instead and saw the Land Rover in a parking lot 2 days ago. It looked like the suspension had colapsed on the drivers side rear. I feel bad for the guy who bought it, but I'm sure glad that it won't be me fixing it.
thanks again guys.
take care.
Glenn In Idaho.
thanks again guys.
take care.
Glenn In Idaho.
on
1 Post
RE: Disco II-didn't buy and happy
No point in flaming someone who made the right choice for himself. The GC is a great vehicle. It just has no personality. That's all !!!
Mike will be the first to disagree, but the SLS is definitely something that Rover should have passed on. Way too unreliable, or should I say unpredictable. Not everybody has the time, or interest of spending time spraying the air lines with soapee water to find why the $%?& the rear suspension is down AGAIN !!! It doesn't matter if you carry all the needed spare parts and you know the system by heart.....That system can let you down in the worst of times, like on a trail !!! You go there to have funoff roading, not to lay down in the dirt while the others keep playing!!! You come out to go to work!!! Not the time!!! ON holidays, hours from home!!! My wife would be very impressed!!!
With this said, that's why I converted to coils. Look on all the forums, and count the number of threads regardingSLS problems. That says a lot about its reliability right there.
But I do however, lift my hat to those who choose to keep it. When all is said and done.....To each his own
ORIGINAL: Lar45
Hi guys, I checked in here about a month ago when I was looking at a used Discovery II. The huge amount of maintenance was the decideing factor of me.
thanks again guys.
take care.
Glenn In Idaho.
thanks again guys.
take care.
Glenn In Idaho.
ORIGINAL: Lar45
thanks again guys.
take care.
Glenn In Idaho.
thanks again guys.
take care.
Glenn In Idaho.
are sold needing work the last owner could not pay or did not want to pay for.
Have fun in your truck,, I believe that its all about off roading and having a good time.
I sure the Jeep-Land Rover thing is just for fun.
As an owner of both, I think both vehicles have their virtues. The L/R is rugged and totally cool. It's built stout and also very comfortable. Some components are known weaknesses, and parts are harder to find. Other areas may be much more rugged. Some engineering systems on the L/R really make me scratch my head.
However, the G/C is hard to beat as a daily driver for pavement and occasional trail use. Most of the bugs have been worked out and fuel economy is noticably better. Ours has almost 200k miles and no major issues. Our neighbor andtwo customersI deal with also have similar miles on their GC andtheir vehicles look great and they've had the same good luck. And also, I don't think there's any more storage space between the two. Plus, the GC usually has a full luggage rack, vs the 1/2 rack for the Rovers. There is no shortage of off-road kits/support available for the Jeep. So, I say, it comes down to preferences and priorities. I agree that the Jeep isn't as solid as the L/R though.
No, I just wanted to say thankyou for the honest info on them so I wouldn't be stuck fixing it regularly.
I love to work on cars, fab and build new parts... but with my rear end accident 3 years ago I am very limited on what I can do now.
I had a 71 Early Bronco that I did a pile of work on. I swapped in a SEFI 5.0 from a Cougar, NP-435 4 spd tranny from an F-100, built my own twin stick parts for the x-fer case, Hinged radius arm, 3.5" coils in front,drop shackle in the rear, 35" Ground Hawgs,onboard air, reciever mounted Warn winch, Nissan Pathfinder power steering...
Almost forgot, 4.56 gears, Detroight lockers front and rear and 4wheel disk brakes.
Here are some pics of me in Moab 2002:
I think the Land Rover would be a great rig when it is running and I really wanted to buy it, butttttt with their track record of lots of work and maintenance needed I thought that it would not really be practicle for me to have it and have to rely on it for daily transportation or long road trips.
In 98 I bought a 93 Cherokee with the 4.0 6 cyl and 5 spd. It has a 3" lift and 31x10.50 BFG MTs. I've taken it hunting and 4 wheeling in the moutains and desert as well as long road trips. When I bought it, it had 92k miles and now has 188k. The only major thing that has gone wrong with it is it started jumping out of second gear when slowing down. I took it in for new syncros and it's been fine since then. I haven't had to replace the brakes yet either. When I first bought it, I got new pads, shoes and hardware kits, but when I took the tires and drums off there was pleanty of life left. I've been checking it periodically and it's still fine.
Sure, everybody and their dog has a Cherokee, but reliability has it's own beauty.
And I do like pickles
take care
and thanks again for the info.
take care
ORIGINAL: Lar45
I had a 71 Early Bronco that I did a pile of work on. I swapped in a SEFI 5.0 from a Cougar, NP-435 4 spd tranny from an F-100, built my own twin stick parts for the x-fer case, Hinged radius arm, drop shackle in the rear, onboard air, reciever mounted Warn winch, Nissan Pathfinder power steering...
Just wondering.
