Disco II driveshaft rebuild
Let me get this straight...
1.Disco II front drive shafts are bad because they did not come with greasable u-joints. If those stock u-joints fail they will ruin my tranny costing me thousands of dollars? 2. If I drop the front drive shaft and replace the u-joints with greasable ones I'm okay?...or do I need to replace the hole drive shaft? 3. Anybody got a link to a site that offers the greasable u-joints? |
You are correct, but have you ever rebuilt a double cardon drive shaft, if not, might want to find a shop that will for around $200.
Parts numbers, Percision 344 u-joint and a Percision 617 centering ball kit. |
For the parts go to rockauto.com.
Here's a good write up on it.
http://www.discovery2.co.uk/propshafts.html and http://static.scribd.com/docs/tkatf9...IAL_VIEW=width |
Can't thank you guys enough for all the help...I will start getting the parts and calling shops today--CG
most driveline shops will carry the parts. Call and get a quote for the re-build and balance. By the time you pay shipping for supplying your own parts, it will be the same as the mark up from the shop.
Originally Posted by Collard Green
(Post 106850)
This is what can happen CG
3 Attachment(s)
(Post 106850)
1.Disco II front drive shafts are bad because they did not come with greasable u-joints. If those stock u-joints fail they will ruin my tranny costing me thousands of dollars? Attachment 48760 Attachment 48761 In case you didn't notice, that's an enormous hole in the side of my transmission, LOL! I bought it cheap because of this. ~Aaron |
So thats what the inside of a Disco tranny looks like!
HAAAAAAAAYYYY wade a minute,
Isn't there suppose to be a bunch of red fluid in there???? |
