disco II ignition alarm
Old Sep 2, 2007 | 02:36 PM
Randy Lover's Avatar
Default disco II ignition alarm
could someone tell me why 3 chimes go of sometimes when i start my disco, it only happens occasionaly, just when you start it 3 "chimes" go off then everything is fine, any ideas ?
Old Jan 15, 2017 | 01:27 PM
LedburyD2's Avatar
4th Gear
I have this and despite trawling around the forum I cannot find an answer, help please?
Old Jan 16, 2017 | 10:34 AM
mln01's Avatar
From the 2004 Owner's Handbook
Anti-lock braking system - AMBER
The light illuminates as a bulb and
system check when the starter
switch is turned to position ‘II’. If
the light illuminates whilst driving or remains
illuminated after the starter switch is turned on,
a fault has occurred. This means that full ABS
control may not be available and you should
seek qualified assistance urgently.
NOTE: Faults which cause the ABS light to
illuminate after the initial system checks, or
whilst driving, will be accompanied by a
warning chime sounding 3 times.
Three warning chimes may also be heard
during engine start-up as part of the ABS
system self-checks. This is normal unless the
ABS warning light stays illuminated after the
engine is running.
Old Jan 17, 2017 | 04:07 AM
number9's Avatar
engine is running.
Thanks for the reference. Good to know if it should occur.
me 2
Aug 9, 2014 05:44 PM
will rocket
Off Topic
Sep 12, 2013 06:23 AM
Kcid1101
Jun 11, 2013 10:19 AM
1998DiscoverySE
Jun 27, 2012 01:56 PM
brian891
Sep 2, 2009 10:57 PM
